Off Roading offroading spare drivetrain parts.
Off Roading limited slip upgrade
Competition Whos buying HVAC'S Red Rocket?
what parts of our drivetrain (or suspension) are really good things to bring extras of? I was thinking u-joints for one, but I noticed that there are a lot underneath our front end alone. 4x4 savvys, what are the must bring along parts and what parts are good ideas anyways?
How about a front drive shaft, then take at least on front axle end. several quarts of gear oil, spare differential cover, couple tubes ATV sealant. Spare fuses, several chains, and nylon chokers. A well stocked first aid kit, small fire extinguisher, water, CB radio or walky talkies. several quarts of motor oil, spare oil and air filter, air or compressor,hy-lift jack, and tire repair kit, a good assortment of hand tools, duct tape, ty-wire, assortment of ty-wraps, two cans of radiator stop leak, can of starter fluid, and not not forget the toilet paper! Good luck
front drive shaft as a whole or just the joints? I have most everything else, the air source will come once the horns are in. Y-knot, my big question is that tire repair kit. In the past (I worked in an auto garage for a while) we always used the flat patches that were applied to the inside of the tire. This method requires a tire machine to unbead and pull the tire off the rim (at least how I'm acquainted with it). When you speak of a tire repair kit, do you mean those rubber strips that come with a threader punch and glue?
Thanks for your response,
Stephan
Yes ... the patch on the inside is better, but not going to happen on the trail. On the front axle, I was just talking about the axle ends. If you had one for a spare it would be nice. Also I took it would had a winch. It would be nice to have a new complete front drive shaft, you could even go to a wecking yard and get a used one.
