Well I broke something. I was getting on the freeway and eased into full throttle and when it was shifting from 3rd-4th (75mph) I hear this huge CLUNK and the rpms went up. I coasted to the side of the road and put it into park, popped the hood and looked under the truck. I couldn't see anything leaking. No oil coming from the exhaust. Nothing from the head gasket. All hoses seem to be hooked up and everything seems to look in order. I get back in the truck and turn it off and check for codes. There were no codes. When I put it in 1 gear nothing, 2nd gear nothing and drive nothing. When it's in any one of those gears if I step on it the engine will only rev to 2100 rpms and not go any higher. In neutral it will rev like normal. Won't move in 4hi or 4lo or go in reverse. Did I break an input shaft/output shaft or flex plate? Does that happen by getting on it with out doing a launch? There wasn't any noise or clanking with it in gear that I could hear. What's wrong with my truck??? :{ :{
