I found a place in town that will do oil analysis with TBN for $11. 75 (First truck Center in Edmonton). They have an onsite testing machine, and can get your results in less than an hour. I was little skeptical so I bought a kit from Stavely Services for 16. 95(no tbn) to compare.
The truck had 33872km and 532 hours and the oil had 12500km and 182 hours. This oil was changed on March 4 and had been used since November. I changed the TP @ 5500km and 9000km. This truck has a AFE proguard 7 intake system.
Here are the results, the first numbers are from Staveleyservices and the second are from First truck Center (Updated on edit I had the columns
reversed )
Iron_______36 - 42
Chromium _ 0 - 14
Lead _____ 2 - 11
Copper ___ 6 - 13
Tin ______ 0 - 12
Aluminum _ 5 - 16
Nickel ___ 0 - NA
Silver ___ 1 - NA
Silicon __ 9 - 23
Boron ____ 3 - NA
Sodium ___ 4 - 17
Magnesium 13 - NA
Calcium 2991 - NA
Barium ___ 2 - NA
Phosphorus 1480 NA
Zinc ____ 1731 NA
Moly ______ 0 - 0
Titanium _ 0 - NA
Vanadium __ 0 - 0
Potassium 0 - 20
Fuel ______ 0 - NA
Vis 100oC 12. 82 14. 5
Water ____ 0 -- 0
Soot __ . 95 - 1. 3
Glycol ___ 0 - 0
TBN _____ NA - 9. 6
Oxidation NA - 2. 9
Nitration NA - 1
Well it goes without saying that I won't be using the First Truck Center for oil analysis again.
Overall nothing to exciting. I will continue to change oil at the recommended intervals of 12,000km. Looks like the soot is under control. I not sure how much effect the Frantz is having on soot levels, but I am happy with only 1% soot, the oil can handle that.
Staveley Services sells a kit with TBN for $20, but you have to buy in quanties of 10, and they are only good for 2 years. I won't use 10 kits in two years. Anyone in Edmonton or Saskatoon, want to go in together on pack of 10 kits?
Carl
reversed )
Iron_______36 - 42
Chromium _ 0 - 14
Lead _____ 2 - 11
Copper ___ 6 - 13
Tin ______ 0 - 12
Aluminum _ 5 - 16
Nickel ___ 0 - NA
Silver ___ 1 - NA
Silicon __ 9 - 23
Boron ____ 3 - NA
Sodium ___ 4 - 17
Magnesium 13 - NA
Calcium 2991 - NA
Barium ___ 2 - NA
Phosphorus 1480 NA
Zinc ____ 1731 NA
Moly ______ 0 - 0
Titanium _ 0 - NA
Vanadium __ 0 - 0
Potassium 0 - 20
Fuel ______ 0 - NA
Water ____ 0 -- 0
Soot __ . 95 - 1. 3
Glycol ___ 0 - 0
TBN _____ NA - 9. 6
Oxidation NA - 2. 9
Nitration NA - 1
Carl
