Oil Analysis Questions
Code P2121
Lion into a Lamb 325-600 question
i just got back my oil analysis from MONITOR and thought they would a legend on how to interpret the data but guess not. the only thing "noted" was under CONTAMINANT METALS column and it says " Potassium is at a MINOR LEVEL. " it shows a figure of 38.
what else should i look for on the report? THANKS
Mainly look for high numbers in common wear metals:
Iron - from cylinder walls
Chrome - from rings
Aluminum - from pistons
Silicon - frequently a bit higher in new engine due to sealants used - but also from dirt passing thru the air filter
Tin, lead, brass and copper - from bearings
Potassium CAN come from antifreeze, but is more commonly seen as an additive to some brands of oil
What's that Gary? Could you say that again? :D
Slow site today make you want to click many times doesn't it.
-Scott
Chrome - from rings
ok, but what is considered a high level? here is in part what it said:
iron 14
chromium 0
nickel 0
aluminum 5
copper 4
lead 1
tin 0
rest of wear metals were 0
additive metals were:
magnesium 11
calcium 3503
barium 1
phosphorous 1158
zinc 1184
THANKS
iron 14
chromium 0
nickel 0
aluminum 5
copper 4
lead 1
tin 0
All your numbers look excellent, especially chrome, nickel and tin.
Anything under 20 or so for iron is good, especially for a new engine - your aluminum, copper and lead are all in good shape - keep using what you're using, and doing what you're doing! ;) :D
Here's a sample of one of my analysis sheets - look over to the right side for what is considered "typical" values:
I just sent off a sample because I wanted to see how good a job my BullyDog (they use an AFE filter) intake is doing. How much silicon (dirt rite?) is too much?
Supposedly, silicon levels CAN be somewhat higher in a new engine due to material used in some sealants - but I would normally consider anything under 10 ppm or so as reasonable...
