My 2004 5. 9L 2500 has oil burning smell in the cabin at idle. Moving down the road there is no issue, but stopped in traffic or at a long stop light the cabin fills with the smell. The odor comes through the vents and you can make it go away by putting the A/C on re-circ mode. Fresh Delo 400 was just put in by a good independent mechanic -- very clean job with no oil spilled. I've heard that these engines are very sensitive to the type of oil used, and I've had numerous problems with my combo Ford/Dodge dealer mechanics often fudging it with Ford oil, which I notice instantly and have to take it back to make them re-do the job. I'm familiar with the putrid smell of the Ford oil, but I'm surprised to have an issue with the Delo (which does smell slightly different). Should I be looking at problems other than the type of oil? The dealer has fessed up to using the wrong oil each time (about 4 or 5 times), changes it, and claims there is no other problem but I'm starting to wonder. Truck has 110K miles. Is there some other problem that would cause a burning oil smell in the cab?
