TP belongs in the bathroom:-laf
How does your oil stay so clean? I have a 06 and I can change all the filters and the Frantz, new oil, start her up, and before I can check for leaks the oil is black and stays that way for the next 10000 mi. I change the Frantz every 2500 mi. and the fleetguard every 10000 mi. then i start all over again.
With the oil bypass filter setup, overtime, does the bypass help prevent the oil from getting "thinner" (i. e. diluted)? Or one of the reasons for oil to 'appear' thinner is based on mileage?
I recently bought a used '04 CTD and just chg'd the oil (3k), 15w-40. Stock setup. It seemed to me (a newbie) that the oil was "thin" and flowed out of the oil pan somewhat like water. I have read some of the other threads re: "thin/diluted oil" relating to possible injector/CP3 leaks - hence, fuel mixing in with the oil. But I am trying to watch for the various leak signs folks had mentioned. I plan on doing an oil analysis soon to get my numbers, which may point to fuel in the oil. I don't want to change the course of this thread, if my issue is related to 'fuel in the oil'.
Oil is going to turn "BLACK" in use no matter what kind of filtration system you use, as the "black" is sub-micron "SOOT" particles.
Soot comes from the combustion of diesel fuel and is a problem because of tougher emission regulations. Less soot goes out the exhaust now, but more goes into the oil.
Wayne
HOWEVER, the length of time to turn black varies greatly between filters... some have finer filtrations and better holding capacity than others.
Odds are he has an '04 or earlier truck without the third injection event. Even with a bypass filter it's a fact of life on the '04. 5 and up trucks your oil is always gonna be black no matter what.
