Oil Change
Did my lift pump just fail?
DDII and Brakes
I have just recently purchased a 1999 2500 24v, and since I had no history on the maint. I was going to do an oil change, I had everything ready and went to loosen the oil pan drain, and found it to be secured very tight! I didn't want to mess up my oil pan so I stopped there to check with you guys to see if there is something I am doing wrong or do I just need to use some advantage
Thanks
Jay
That happens sometimes, most likely dealer were doing the service for him, and the kids that do their work don't want no a$$ chewing for a drain plug coming off and costing the dealer a new eng. May have to use a cheater and hold your breath. Good luck.
