My 99 2500 CTD has developed a small, but piddling leak from one of the fittings on the oil cooler lines which run to the oil-to-water cooler by the engine radiator. The guys at the shop I take it to for normal maintenance said that the lines are a dealer-only item and cost about $260 bucks!
Is that true? Does anyone else have any other resources for those lines?
Also, if I'm getting a puddle of oil about 1-1/2" in diameter intermittently under this fitting, is it something critical to repair?
Or can I wait on this a little while. I guess the real question may be, what sort of pressures are these oil cooler lines supposed to hold?
Thanks!
Eric
Thanks!
Eric
