oil drain for trans
Oil Drain Finger-touch
GoRhrino wheel to wheel Stainless Bars
Any one put in a drain plug in their trans oil pan? I think that this would make for an easier, if not less messy experience. Pull the plug, let it drain then pull the pan and filter.
If so what size? Is there enough room in the pan?
Thanks in advance,
J-
For the little money, get yourself a Mag-hytec. it already has a drain plug, and you can add more fluid capacity if you wish.
HTH
George
The Mag-Hytec is nice but way too expensive. Geno's sells a plug for the stock pan that requires no welding, just drill a hole.
