Thanks Dreher for the thread link and everyone else for the comments.
I'll go down to Napa and buy a piece of that grey gasket material and make a 2nd larger gasket, RTV it to the pan and reinstall the factory plug and gasket. We'll see how that works
and let Y'All know
Thanks
Well I hope I fixed it. I got the gasket material and cut two 2" dia. gaskets(they fit the pan recess). Punched a 3/4 hole in each with the 3/4 sharpened copper tube (worked great). Cleaned everything up with laquor thinner. I mixed up some J B Weld which I carfully applied between the 1st washer and the pan. Then I applied some copper RTV between the 1st and 2nd washer (so I can use a new one next oil change) and between the 2nd washer and the factory washer. Then carefully assembled the works (so as not to get JB Weld on the plug threads). I torqued the plug just snug and let set up.
Filled with oil (just to make sure nothing stuck together that shouldn't).
Cummins said that engine takes 11qts -- 1 in new filter 10 qts in the pan ( they said to let drain over night to get full drain down of oil for a clean oil change. If you don't let it drain it takes about a qt. less oil).
This has been confusing to me till now
The dipstick shows full with 10qts. in pan after a complete drain down in a cold engine ( the add mark is at 8qts. So a WARM engine should show about 1/3 down below the full mark but above the add mark). Only 1qt should be added to a WARM engine if it shows at the add mark.
Anyhow -- hope this fixes that problem
Time will tell. I don't like an $8000 engine to leak oil
Thanks for all the help especially the copper tube cutter
