oil filter for aisin transmission
Has anyone found a source for gears?
2nd Gen DPF Delete - Regenning??
any one know if there is a filter in the new aisin transmission (3500 cab chassis),and where we could get it,and when it should be changed
Regards
conn
Fluid change is 30,000 miles regardless of usage. The filter only has to be changed if metal is present. The pan has a drain plug so you don't have to drop the pan. Use a clean container and look for excess debris to determine if filter needs to be changed.
Gasket 68020049AA $33 net $54 retail
Filter 68019688AA $94 net $157 retail
Fluid gal 5189977ab $26 net $43 retail
Service fill is 7. 2 quarts
sag2,
Is there an approved alternative fluid for the Aisin transmission? I'd like to buy a quality brand name fluid that meets Chrysler/Dodge specs from an Autozone or other parts retailer if possible?
This is already reported in another post but to close the loop I found the answer. The Aisin uses ATF+4 according to the parts department of a local Sterling truck dealer.
The Aisin does NOT use ATF+4. It uses special Aisin fluid as I posted before. This caution is from TSB 21-014-07.
NOTE: This Service Bulletin DOES NOT apply to the following transmissions:
• Sprinter transmissions
• Crossfire transmissions
• MK/PM vehicles equipped with Continuously Variable Transmission
(CVT)
• WG vehicles equipped with a diesel engine (sales code ENF) and a
W5J400 or NAG1 transmission (sales code DGJ)
• **ALL vehicles equipped with a AS68RC Transmission (sales code
DG3)**
• **ALL vehicles equipped with a GENTRAG MPS6 Transmission (sales
code DG5)**
Dodge Ram C&C Aisins and, apparently, all Aisin transmissions use Mobil Multi-Vehicle ATF available at Autozone and other auto parts stores. Look for the "JWS-3309" specification on the bottle.
