Fluid change is 30,000 miles regardless of usage. The filter only has to be changed if metal is present. The pan has a drain plug so you don't have to drop the pan. Use a clean container and look for excess debris to determine if filter needs to be changed.
Gasket 68020049AA $33 net $54 retail
Filter 68019688AA $94 net $157 retail
Fluid gal 5189977ab $26 net $43 retail
Service fill is 7. 2 quarts
