Oil Filter question
Newbie on Mild Box/Programer etc. knows bugger all...
P0088 Code?
ACoyle
Super Moderator
OK, here's the question. It is necessary to do an oil change relatively soon, possibly before I can lay my hands on a fleetguard. What wi the best acceptable substitute. I am currently running "dino" and will change in 3K again.
Thank You
AC
No it is not necessary to do an oil change early. Use your best judgement and change it as close to the 7500 miles as you can and you will be just fine even if you go over that a bit.
Thank You
AC
I change oil and oil filter every 5000 miles. You can even go longer. See owner manual. I like Delo 400 15W-40 and Fleetguard. Grizzly :)
Thank You
AC
Try the Dodge dealer you bought the truck from. They are only $11. 00 (not really alot when you consider the price of the truck)
