Easy way
I bought a wrench from Snap-on and the pin that doesnt hinged I ground down as to remove. Pull the pin wrap the strap around the filter reinstall pin move wrench up to top or near top where the lip is and as you turn the handle you cinch up and turn to get off. Works great and was real easy that way. When loose pull pin and take wrench out. Put zip-lock bag around filter and take off. Oh, I had enough length on the stock pin, but putting a longer pin would help to pop up tp grad to remove. Works right or left, just put pin in from top. What I mean is hinging lever. The pin ground is closest to the handle.
