oil filters
Rear wheel seals leaking after being replaced
NP273 drain plugs and Eng Oil Filter question
FLEETGUARD - STRATAPORE
LF16035 and LF3894
Are they the same except for the fluted can shape on the LF16035?
Some dude on some cummins forum was posting several repeated times that the LF16035 was a way different filter inside, a special designed venturi super-duper filter that is needed for 2003 and newer. He said you cant not run a LF3894 on 2003 - newer.
Sounds like the dude is full of Bull
No-one has heard of this super venturi design LF16035
My search comes up with nothing also.
I figure the experts here on TDR would know for sure
He just had the wrong number, it's the LF9028 extended life filter that has the venturi filter in it.
I used that filter my self for a couple years but later considered it as to expensive because I don't extend the oil change interval what that filter is designed for.
And no there isn't a need for a super duper filter at that industrial engine, it isn'ta Ferrari.
It is happy with a filter of any brand reputable. Regular oil changes are way more important then anything else.
