First off I am an no way affiliated with the company I am about to endorse, just a very happy customer.
With the price of fuel/oil on the increase I thought I would put this out for some to read. I have been using the products from Superior Friction Reduction Corp (SFR) since about 97 when I saw first hand the "bearing test" at their facilty in Montana.
This test basically showed how well the oil fortifiers worked at reducing friction and adding protection to moving parts where any oil is used to lubricate/cool.
You add these fortifiers to your oil, engine, transmission, diff, etc and they will enhance the lubricating ability of the oil. Making less friction and better protection against heat and contaminents.
You will be able to extend drain intervals and use less expensive oil in your truck with the use of these fortifiers.
I am no way a chemist and understand this, but I have seen the results first hand when I pulled the heads on my 90 gasser, I also completely swamped my fourwheler 3 times and had water and silt in the crankcase and it still runs great and used no oil.
The website is Oil Additives, Lubricants, and Fuel Additives - SFR Corporation the gentleman I talk to is Mike, he is very helpful and can explain things better than I ever could.
Some of you may be skeptical, others may try it. IMO this is no different than spending the extra money for high end oils like Amsoil. How do we know it is a better oil? Can you see the results in your vehicle? Some say yes some say no, this is no different. This product is something I have seen results in and want to share it with the TDR community, it may be of some interest to some of you. I do not want to start an agruement about oils here. This is just FYI.
If anyone else has used this product, tell us your experience good or bad.
Thanks
Jason
Thanks
Jason
