breather
My truck is a 1990 w250 with the banks intercooler kit. The breather tube sticks down the drivers side of the motor terminating about flush with the bottom of the oil pan, the oil spatter is on the bottom of the fuel tank and transfer case cross member from there it lands on the drivers side rear diff. My tuck has a 4 inch lift with 35" tires, if the spray is not uncommon I am wondering if I need to put the tube closer to the ground such as the stock configuration would have been? When I park at night it drips in the driveway, the spot is about the size of a dime. I thought this was not to abnormale from big trucks I have seen. Do you believe RPM may have anything to do with this oil spray? It seems to occcur more when i travel down the highway at 70 mph which is about 2000 rpm with my 4:10 gears and my NV4500 transmission. Should I decrease my highway speed? Thanks for the replys I really appreciate them.
