Oil Housing Plug
Speed / RPM's / Boost
Error Code P1693-Back to the dealer!
Recieved my Bypass filter yesterday. Does anyone know what the thread is on the plug on the top of the oil filter mount on the Cummins? This looks like the cleanest spot to tap for oil.
Rich
2001. 5 2500 ETH/DEE 4x4,Patriot Blue over Silver,Camper pkg, Trailerpkg,3. 54LSD, Agate Leather,Stainless Smitty Bars,Tow hooks,Amsoil... ... ... :) Except snowplow!
It is a test port, lots of guys mount their oil temp sending unit there. I believe it is a 1/8" female NPT thread.
Dave
2001. 5 2500 QC, LB, 4x4, Auto, 3. 54, Everything but Leather, Bright Silver Metallic, ARE K Series, Diprocal EGT, Boost and Autometer transmission Temp(sensor in the line) in an Autometer Dash Pod, SW Fuel Pressure Gauge, Westin CPS Platinum Step Bars - Black on Stainless
Great White
That is where you tap in to supply the bypass filter. I am assuming an Amsoil setup. Return to the oil fill cap with there fitting about $12 extra.
Doug
O. K the test port is 1/8" FPT. The filter I purchased is the Oil Guard EPS 20. Looks like nice unit, Anodized lid w/ powder coated cup. Very heavy duty, road trash will not dent it. String filters are simple to change and not very expensive.
Next I will stop by Angeles Valve for some S. S. fittings. I think I will get a bulkhead fitting and return the oil into the valve cover above the oil filter. I think the unit will be mounted on the frame rail under the turbo. looks like plenty of room with reasonable access. I may have to move the front axle vacuum lines slightly.
Rich
2001. 5 2500 ETH/DEE 4x4,Patriot Blue over Silver,Camper pkg, Trailerpkg,3. 54LSD, Agate Leather,Stainless Smitty Bars,Tow hooks,Amsoil... ... ... #ad
Except snowplow!
[This message has been edited by Great White (edited 04-03-2001). ]
