Archived Oil inside the vacuum pump
Archived Broken down
Archived 2003 die crank no start
I have a oil leak between the vacuum and the power steering pump.
I removed the vacuum pump and started to install a new seal kit and found that the entire cavity of the pump was filled with engine oil. Is this normal and where does the air exit the pump?
I have been having low vacuum pressure for some time.
Any out there know how they work?
