oil jet banjo bolt spec?
HELP! 48re won't shift after service
off idle stubble
anyone have the torque spec handy for the oil jet banjo bolt? I can't see it being any more than about 10ft.-lb. with red Loctite.
This is on a 2007 5.9
Yes, interesting. That is what I found also. After posting this, I called Cummins, whom said on the Dodge Engines they give all specs to Dodge and they connected me with Dodge. They in turn could not find a torque spec and referred me (and connected me) to a "helpful" dealership whom said they would research and get back to me. I was surprised when I received a call back in about 30 minutes and said nothing available.
I did find out that they recommend all new banjo bolts and suggest all new j jets. We're going with the new bolts and well cleaned jets.
So, 8 to 10 with red it is.
Another odd find. The fsm specs a torque for the back half of the timing gear case and states to follow the tightening sequence. That info is no-where to be found.
