Engine/Transmission (1994 - 1998) Oil Leak behind Turbo??????
Engine/Transmission (1998.5 - 2002) no heat on feet
Engine/Transmission (1998.5 - 2002) electric fans
Attached are some pics. Maybe this can explain my other post about the whining noise when getting on the accelerator and low power. What causes this? Is it a bad turbo? Worse? I can actually see oil coming out between the turbo parts.
As the old joke goes, it looks like you blew a seal. With that much oil showing I'm betting your crankcase gets low quickly.
I have heard of turbo rebuild kits, but have never used one. It may be only a seal you need, or the noise could be a bad bearing. If you can afford the down time there are several places to get yours rebuilt. I recommend PDR, either have yours modded or use it as a core.
Hey98ramtough sorry I haven't given you a holler yet but will call you in a few. I had a used turbo sitting around but don't recall what I did with it or if I sold it. I will look some more. If I were you I definitely wouldn't drive it because the turbine could well be rubbing on the housing which generates a lot of metallic dust which gets sucked through the engine.
Does it make a fair amount of black smoke when you try accelerating?
