I don't know how to link to my old post so to see the full story look under (Need Help Oil Leak). This trip to Dealer #5 was like leading a horse to water. I had to suggest for them to run it to see it leaking, also had to leave my black light and yellow glasses with them because they didn't have one. I finally was able to pick up my truck on 01-03-03 and this is what they found. An O-ring was missing that seals the opening between the adaptor plate and Cam on the engine block. I know this for a fact because I was there when they pulled off the adaptor plate and I took pictures. I never got oil on my clutch. Now I will try to attach my pic.
On the adaptor plate you will see a cut out ring on the upper right side--this is where the O-ring should have gone. On the engine block pic you will see the cam opening on the left side. Thanks for all your help and suggestions.
Don
Don
