grabinov
I have an engine oil leak coming from the rear of the engine. It appears to be coming from the point where the back of the block (where the oil pan ends) mates with the the adapter which then mates to the bell housing of the transmission. It may be coming from the rear of the oil pan gasket.
There also appears to be engine oil leaking from (or at least dripping from) the little cover on the transmission (which I think provides access to the toque converter). It's not trans fluid - which seems odd.
Is the main seal between the block and the adapter, or is the main seal the thing between the adapter and the transmission? As you'll see from my signature, I did have the trans out about 12,000 miles ago for a rebuild.
Any thoughts on where the leak may be coming from?
