Details here: TDR Privileges
Any oil running down the filter? The oil line to the turbo may be leaking. Mine is doing something similar, one of the fittings is drippign, But it is a PITA to get to. If that is not it you may have to tighten the oil pan bolts. I have given up on chasing down the rest of my leaks.
I have the same leak starting at 180,000 km. A few wet drips along the front edge of the pan and along the compressor like you.
I will hopefully take another look tomorrow but my guesses are loose pan bolts (easy to tighten, gotta check the torque on these), and then I'm looking at the front seal as the next possible culprit?
Any chance you have a double gasket on the oil filter? The placement on the filter is terrible on these things. I always prefill my filters and the slightest wobble during install, oil goes everywhere.
Still haven't been able to get this leak fixed. I had the front gear cover and crank seal replaced. That didn't do it. It looks like it's coming from the front corner of the oil pan at the intersection of the front gear cover. I'm wondering if I clean it up with solvent and apply a sealant?
The manual says you have to take out the transmission to remove the pan. If I did have to replace the pan gasket is there a trick without removing the trans?
OK got some pics.... any suggestions where the oil is leaking from?
It's not the pan. I did a thorough cleaning and removed the pan bolts. I cleaned up the bolts in acetone and cleaned out the holes with alcohol. I put RTV on the bolts and re torqued. I also wiped some RTV on the corner of the pan/engine interface.
Next day... pretty obvious the oil is not coming out of the pan. It's coming from somewhere higher. The front cover and front main are just done. It's either the gear case or something above leaking. Any suggestions?
BTW it leaves a puddle about 2" dia. everytime I park.
Maybe where the oil filter and cooler assembly bolt into the block? Might run down and toward the front of the engine. Looks like some stains in that area in the photo.
I am quickly coming to the conclusion that the gear case is leaking. As you can see in this drawing the oil is coming from above. I did a big maintenance stint this Saturday. Replaced the water pump, belt, hoses, coolant and dif fluids. While I had the air cleaner off and the water pump out I removed the alternator. No sign of a leak. It only leaks when it's running. I cleaned everything up with alcohol and put RTV along the edge of the gear case. This morning since it didn't run it was dry as a bone. I drove to work, climbed under and low and behold, oil running in the corner of the alternator bracket and gear cover. It seams the gear cover is leaking up high on the left side only when the engine is running. I did torque those bolts a little more but it didn't help.
Next step... Remove air cleaner, remove alternator, remove water pump. Clean up with solvent and RTV the joint. I'm using Permatex gear oil RTV. The stuff really grabs.
Maybe some day I'll do it right id this doesn't buy some time. Too big of a job for this level of a leak.
The second photo is a picture from another site. I believe the leak is from the area of the gear case where the oil pump is.
It is certainly possible that the gear case gasket is leaking. If you had an older engine I would suggest the KDP had bit you. To replace it requires removal of the cam, so it is not an easy fix. Since the oil is not under pressure there may be an external sealing substance that will do the trick.
