Engine/Transmission (1994 - 1998) oil leak- lifter valley cover?
Engine/Transmission (1994 - 1998) 1995 pcm part #
2nd Gen Non-Engine/Transmission front end nightmare!!!!!
Anyone ever have the an oil leak from the lifter valley cover gasket? How hard is it to get to to replace? Do you have to remove the injector pump? Thanks. -Josh
Mine is leaking in the rear bottom corner of the valley cover also. I tightened the rear bolt a little, hopefully that seals it up.
