Engine/Transmission (1998.5 - 2002) Oil Leak, OilPan or Rear Main
Wiring problems
New fan clutch
2001 2nd Gen Truck.
I have an oil leak in between the engine Block and the transmission.
I cannot tell if it's coming from the oil pan gasket or the rear main..
Is it possible to drop the oil pan as it sits?
It doesn't appear possible.
Thanks. Gary
2001 Dodge Ram 5.9 Diesel. Stock Truck
Not sure if the 5.9's have a balance shaft seal, check that out as well. Mine was weeping and replaced under MaxCare.
