lmills said:did you take the plastic cover off and actually see it leaking from there? Or is it just leaking out from under the plastic cover in that area?
I FOUND MINE TO BE THE O-RING ON THE OIL FILL CAP, REPLACED WITH A CAT O-RING AND NO MORE LEAK, I PULLED THE PLASTIC COVER AND CLEANED UP THE OIL, DROVE IT FOR A DAY, THAT IS HOW I KNOW WHERE IT WAS COMING FROM...WPeschel said:Has any one had a oil leak coming from around where the breather is mounted onto the top of the valve cover under the plastic cover??
