I've got a bad oil leak, it leaks when it's running and when I poured oil into the crankcase. There's an oil line on the drivers side of the block below the injector pump. I noticed it was leaking and continued to drive it. I filled the oil on a sunday. Friday I was driving home from work and noticed at idle, the oil pressure would drop to 0! I got home, checked the oil and it was about 1 1/2 to 2 gallons low. When I poured oil in, it began to leak out of the same spot. Could my head gasket have gone bad? Is this where the head meets the block? Thanks for all your help.
Here is the best pic I could get of it.
<a href="http://s799.photobucket.com/albums/yy278/drewmendoza/?action=view¤t=DSC_0288.jpg" target="_blank">
</a>
</a>
