Engine/Transmission (1994 - 1998) oil leak
i have a very slow oil leak coming out from somewhere under the injector pump closer to the under side of the afc housing i took some degreaser and my grandpas pressure washer to clean it all off. i drove it for about 15 min. and it was clean drove home to Waco (about 7hrs) and it was leaking very little again any idea where it could be coming from i cant exactly pinpoint where.
P. S. new fastest E. T. 14. 90 @ 91mph
I am working on a customers "97 with the same problem. Seems to be coming from between the timing cover and the block. PITA because you have to pull the cam to replace the gasket. Haven't started the repair yet. Will post again during the repair.
Seems we have to sacrifice some repair vs power that may not be necessary with a stock application. IS ANYONE STOCK??????
hsmith
