Yes I know diesels are supposed to leak but...
I have a rediculus leak that I attribute in part to the front crank seal being on its last legs as well as the timing cover gasket poking out the inside corner of the cover (right around the injection pump). Dodge says they want 14+ hours of labor at god knows what rate to replace this gasket. I agree it is a job since you have to pull the camshaft, but please... My question is this, can I cheat and pull that cover far enough away from the motor with OUT removing the camshaft to slip a new gasket in, and yes I know it would have to be cut to pass around the camshaft (the slice could be at the top of the cover so oil is not always sitting on the gap plus a little gasket maker never hurts. As of right now the temp fix is permatex on the ouside of the case were the case cover sits against the block... works pretty well for 6-8 months until the oil wins the battle. I would keep up the fight that way, however, like I said earlier, the crank seal is leaking.
Plan B. If I get responses back saying the cover doesn't move as much as I want it to, does anyone have a Dodge special part kit for holding the cam journals up off the cam to remove it. Seems silly to have to pay full price for a kit I will use once, if that.
If anyone has done this job, is it as much of a pain as the technicians say it is?
