Details here: TDR Privileges
Might also be the rear cam plug, or the valve cover leaking and dripping down. You need to clean it good and see where it's coming from. If it's inside the bell housing, most likely the rear seal. If it's between the oil pan and the adapter plate, might be the seal or the cam plug. If it's wet up above the bell housing, hooray! you hit the easy one to fix.
