Oil Leak ?
HO or no for Tow??
2010 diesel water/meth injection
I've got an slight oil drip on my floor mat, just under the accelerator. Can't tell exactly where it's coming from, any ideas?
Seems to be slightly leaking from a piece attached to the brake pedal. The part is black plastic connected to metal. Just barely a drip, looks like it's seeping out where the metal and plastic join.
I think I've found my problem. There is a bracket attached to the brake pedal arm that holds a motor and worm gear to adjust the accelerator and brake pedal. The motor is in a plastic case attached to the metal bracket with two torques head screws. One was a little loose. Tightened it up gently, wiped off the oil drop. We will see if that fixes it. Can't tell for sure if the plastic motor case is cracked.
