Had my 96 off the road for 5 years, just started running it again. before I semi retired it, there was an oil leak, the type that sprays oil under the truck as you drive, then when you stop about 2 5 inch puddles form. After it sits no more oil will come out. Since bringing it back on the road I've tabbed the KDP, and replaced the vacuum pump, after starting it up there was a pretty fast drip of oil coming from somewhere just above the vacuum pump area, could this be the tappet cover? Been hoping I would never have to remove the IP pump, but maybe I'll have no choice now. Thanks for any help!
