For the last week I have noticed a 4" diameter
puddle of oil on my driveway. The drops are coming
from the bottom of the bellhousing, with other
drops of oil accumulating on the oil pan bolts on
the right side of the block/pan. I traced the oil
leak to the fitting that slips into the block
where the turbo oil return pipe goes. The front
of the engine is dry, as well as the left side of
the pan/block gasket area, and the rear main seal.
My biggest worry is leaving my new truck at the
dealership for two or more days (lots of horror
stories about lot monkeys that can't drive a stick
or run into poles etc
). I'm sure it is an
easy fix. I also dread thinking they may think
it is the pan gasket or rear main seal and tear
the truck apart only to make things worse.
In other words, am I the only one that DREADS
taking my 'baby to the dealership?
-Chris
Lake Conroe, TX
-Chris
Lake Conroe, TX
