HI All,
My work truck recently had the oil light to flicker on at idle at a stoplight... . I did notice that the factory oil gauge pressure was a little lower than normal but at the same time my brake control had it's LED light on for no apparent reason so I partially discounted the possible problem as an electrical gremlin. However, being ever so cautious... I decided to check the oil level anyways... . The truck does not usually burn any oil... . It does however have a slight leak on one of the valve covers that I will soon address..... To my surprise, the engine oil level was way way above full (a good 3 or more inches above the max fill line)... . I had changed the oil a month or so ago but I know to use 3 Gallons of Rotella so I did not over fill the oil myself and I know my helpers didn't add any oil unnecessarily... . I tried smelling the oil and it seems ok... . no antifreeze smell or anything. . it did seem a little thin tho considering I lowered the engine oil level by pulling the oil drain plug and I did it while everything was cold... Another friend said it may be a leaking fuel injector? How likely is that? How would you check for that?... . I suppose I really shouldn't drive the truck until I figure out what is wrong with something as important as oil... If it is injectors how expensive are they and where should I buy them... . I hear they can be a pain to change out so unfortunately I may have to go to a shop for that... . Would it be OK to drive it there? (about 5 miles distance).
Thanks in advance for any and all help.
Andrew
Thanks
Andrew
Andrew
Thanks
Andrew
