Ummmm, oh boy.......
Dbonzi, I hope I wayyyy out here but... .
Let me tell you about my younger brothers Toyota... . I know its not the same but what happened is...
I swear it's the god's honest truth.
Going up a long grade, camper, utility trailer loaded to the rails...
He's turning 4000 RPM in 3rd.
Next thing we know we see little tiny blackish spots on the windshield. We pull over and open the hood.
Funny thing is the dipstick is hangin out of the tube, just barely a couple inches left in the tube, oil everywere.
We check the breather, its ok, check the oil, add a quart and I tell him to go and 'light it up' lets see whats what.
He fired it up and gave the throttle a quick poke... ... well, I damn near lost my beak!! :--) :--)
The dipstick came out from the tube at about 200MPH and went a full 40 feet up the highway before hitting the ground and sliding to stop.
The moral of the story was, broken compression rings in 2 cylinders were letting cylinder pressures into the crankcase and pressurizing it big time.
If your breather is clear then I'd be concerned. Lord I hope I'm wrong on this one.
2 psi of air is not enough to force oil up the tube ahead of just seeping out the overflow. It will go that way first, before moving the oil all the way up that tube. If your ran 100 PSI you might see a different result. Remember, the breather is darn near a 1 inch dia. tube
You may have a problem elsewere, mmmm... crack in block/oil passage area, hole/crack in a piston head, or what else I'm not sure.
Was there any funny noises/sounds leading up to this?
Any other observations prior to and when it happened???
I think the only way to get oil out of the dipstick tube is to pressurize the crank-case.
Do a quick test, plug the breather and start the truck. No high revs. just 750-1000 RPM's. Watch the dipstick tube for spouting.
If it spouts, you got problems. Any ugly sounds, roughness idling??
Geez, I hope I got this all wrong and I'm just blowin wind
BTW, I do not think the 'adjustment' to fueling is the cause, unless you went wild and broke/collapsed a ring in the process.
Please let us know how it goes. Good luck
Bob.
