With the transmission and clutch out of the truck, can the oil pan be removed by just jacking up the front of the engine and tilting it back far enough, without messing with the engine mounts, to gain some clearance around that crossmember? Or if the pan cannot be removed that way, can it at least be dropped far enough to remove the old gasket and install a new one?
Also, is it best to install this gasket with some RTV or install it dry?
Thanks, Joe
Thanks, Joe
