Oil pickup tube location in oil pan?
HELP Need AuTo ElecTriCian in DFW ASAP!!!
Tst Box - Driving Results
I'm going to be punching a hole in my oil pan tomorrow for a self tapping hollow bolt, but before doing so I wanted to find out where the oil pickup tube is located at. Need to make sure I don't punch a hole and have the pickup tube as an obstruction behind the hole. TIA.
the pick up tube starts at the front of the motor, it runs down the passenger side of the pan next to the pan bolts, then turns down at the back of the motor, and then is running along the bottom at the very back of the pan.
hope this helps
hope this helps
Good deal. Thanks snox!
