Oil Pre-Lube: Anyone Have Information
Installed Donaldson 51" muffler, 2000 RPM drone is worse than magnaflow!!!!
fuel tank pick up tube grommet
our big CAT units have pre-lube systems on them, but it's probably overkill for our trucks... let the thing idle for a minute before you put a load on it and you're golden
you could make one with a hydraulic accumulator, solenoid valve and some misc plumbing parts. it would not prelube on the first start up after an oil change, but after that one, it would prelube [or post lube depending on settings]
