I've noticed that at initial start-up, my check engine light stays on for a couple seconds longer than the other lights. The oil pressure gauge is reading 0 during this period. Once the pressure pops up to @40psi, the check engine light goes off. Obviously, the check engine light is on because it sees the low pressure. Should I be concerned? Is this normal? I don't want my engine running "dry" during that entire period. Shouldn't the oil pressure (gauge) go up almost instantly? I have and Amsoil bypass filter set-up on the truck for whatever that is worth.
Thanks in advance!
Thanks in advance!
