oil pressure question
HELP! Code P0700?
Torque Converter & VB Recommendations
:confused:what are you guys seeing for OP at idle and WOT? im going to get a oil pressure guage, to replace the "glorified idiot light" dodge has in the dash on my 06. but i have two choices full sweep electric or short sweep. so i just need an idea where the OP stays so i can deicide if i need fine monitoring with the FS or jus the SS>. . thanks guys!Oo.
My numbers agree with steved's. I would say that ~60 psi +/- 5 psi at hot cruise would be normal. ~20 psi +/- 5 psi normal hot idle.
This is measured from the oil filter adapter. A gauge installed in the main oil rifle will read different (probably a little lower).
I run a 270° electric Isspro gauge.
Ryan
20-70 normal on my 06. SPA gauge stored a max reading of 150 at some point. I cleared it and it's back up near there again.
Interesting side note. I picked up an 89 with about a half million miles on it and it idles at 20, cruises at 60 as well :)
hot idling with 0w40 in the sump, off the gallery left side of engine. . 18psi my el cheapo electric gauge in the cab doesn't read right as the transducer is no good, but my mechanical underhood gauge reads true
My low pressure warning light is set at 20 and it's gotta be really hot to trip it. This is with 15/40 of course.
