Oil Pressure Sender
ISB Stinger-Plus Installed...
Airvalve extenders for dullys
After reading about the $7,000 engine that blew up because of no oil pressure, I made my last trip starring at the oil presure gage. As an idea why not have an audible oil pressure alert? I have disconnected the brown wire on the door switch to kill the "bonger" when door is open. There must be some way to tie the brown wire into oil pressure idiot light wire to make an audible warning. Anyone have any ideas?
In the ISBs the computer will kill the engine if the pressure drops below minimum allowed. There is also a low oil pressure kill switch available from Mopar performance parts -- although that particular part may only be for gassers (used predominately in dragsters).
Big MAK
98. 5 ISB 5spd 4x4 Quad Cab 3500, 4" Exhaust elbow down, PowerMax1, dang near everything else
https://www.turbodieseltrucks.com
I don't believe there is a kill switch when oil pressure gets too low. On two occassions, I've lost oil pressure to zero while offroading on freefall declines. Engine never did shutoff.
'98. 5 Dodge Ram 2500, 24V Cummins, 4x4 QC, 22,000 miles, Driftwood, all leather interior, auto-transmission, 3. 54 gears, K&N filter, Westin chrome nerf bars, Rhino-lined, SS bed rails, and BFG All Terrain 295x75R16s
'93 Jeep Wrangler, 25,000 original miles, 4. 0L, 5 speed AX-15 transmission, Atlas II 4. 1:1 T-case, Tom Woods drive shafts, Warn Extreme coil over suspension, Dana 44 reverse cut front axle, Dana 60 reverse cut rear axle, 4. 56 gears, all disc brakes, 10x15 Bart beadlock wheels, 35x14. 5x15 SSRs, Warn 9500i winch, custom roll cage, custom front and rear bumpers with swing out tire carrier, Currie air compressor with custom rock slider air tanks, dual Optima batteries, auto wheel balancers and much more!
'98 Big Tex,12,000 GVW, 20'x7' tandem wheeled bumper pull trailer
