Oil Pressure sender
fuel filter change
Wet Carpet
Started to have erattic and then no oil presure indication on my gauge. Checked oil being delivered to valve area and drove home slowly.
Does anyone know what the resistance or voltage should be of the sending unit with no pressure and then at idle about 30lbs. ?.
If sender needs to be replaced who has the best price ?.
Thanks
My sender has had erratic performance for 100k miles. 99 percent of the time it works fine. I was told if the oil pressure really went to 0 the engine would make alot of noise and you would know something was wrong.
I got my last one at NAPA, as I recall it was under $30. I think Dodge sells them for around $70. Some have said the Dodge one is the best and lasts longer. Mine works fine so far and it's been on over a year.
I'm looking to get one as well. Do you know a part number? I called NAPA and they couldn't find one in their system for a 98. I figure that since this is the 24v forum, you are talking about a sending unit for a 24v. I did manage to get a NAPA PN of OP6670 for a 95 CDT Ram, but that would be for a 12v, would a 12v sender work on a 24v? They said that this 12v one would be $23
I'd like to get one for my 24v this cheap.
Thanks,
Nathan
Thanks For the input
Thanks,
Nathan
I will go shopping tomorrow and see what I can find.
Give it ten minutes :rolleyes:
I have the newest and greatest part # from Cummins at home.
Mine did the same thing and As per TSB ..... No way ut uh not gonna plug into me there dodgeyboys. I knew it had to be something like a sender.
So I replaced it and bingo good to go!
Now I think I am going to change ALL the sensors at every oil change :rolleyes: :rolleyes: (as I just puked a couple more... Like the KPS and possibly CPS)
Cummins Part # 3408428 Sens,Prs
<hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Somewhat Powerpacked By Bank's (4 inch exhaust,High ram intake,~Minus~wastgate mod to 38 psi,~Minus~ottomind TLC +guages,K&N) ,Blue Chip Premium FMC DTT~93%TC~&~VB~TC Smart controller, Mag-Hytec's Double Deep Trans pan,DD III injectors+Van Aken+Autometer Guages. ,Piers Modified PDR HX turbo,Enterprise Engine PerformancePusher pump setup Front End Leveling Kit from Jakit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Black Diamond Plate Bed Rails And Tool Box , WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. DynaMat Sound deadening applied to entire cab and doors, Check out Tool's Stuff~>Here!<~
N. E. T. D. P
Three worded story ... ..... "over 1350 response posts - a new record!"
I tried NAPA today and will try a few more part houses. If that fails Cummins will get my $$$$ instead of Dodge.
