Engine/Transmission (1998.5 - 2002) Oil pressure sending unit!
Engine/Transmission (1998.5 - 2002) 20K with "0" Defects
Engine/Transmission (1998.5 - 2002) 1 year fuel mileage
Where on our trucks is the oil pressure sending unit located??? Does any one have a pic??? Also does any one know what thread is on the unit..... 1/8 or 1/4 npt or bigger????
Left side of the engine, right next to the ECM, almost right below the fuel filter. You will see 3 wires going to it. Not sure about the thread tho, but a 32 MM deep socket will get it out of there, a six inch extension on the ratchet makes it easier too. .
Glenn
It uses a metric straight thread O-ring fitting not sure on the size. If you want to hook up a mechanical gauge there is a 1/8" NPT port on top of the oil filter housing right next to the feed line for the turbo much easier to get to as well.
