oil pressure using amsoil
Additives - Stanadyne -VS- Lubrication Engineers
Bombing with the EGT probe in the exhaust elbow.
I am thinking about switching to amsoil. What
will it do to the oil pressure?Raise it,lower it,remains the same as Premium blue
is now
I was using Rotella 15-40, and switched to Amsoil 5-30. NO drop in oil pressure,not even after 35,000 miles on the same oil.
I was expecting a slight drop, but noone I've talked to has had one.
GENE
1997 BOMBed 4x4
NRA Member
GLTDR Member
LIC-ROC Member
Switched to Amsoil 5W30. Noticed no difference
in oil pressure. My son uses it too,same thing
in his 99 mine is 2000 model.
I also didn't notice a drop in pressure using 5w-30. Actually it remained constant... longer than Valvoline Fleet 15-40.
I did however notice a slight drop in pressure after adding the dual remote by-pass system, but nothing to cause a worry.
98. 5' 24v 2500 Auto/3. 54 4x4 SB QC. Everything but leather. PIAA driving lights, AMSOIL oil filter relocation system,Smittybuilt Stainless Steel Nerfs,Rhino Liner,K&N air filter. Somehow lost my silencer Ring.
My oil pressure went UP 5psi going from Delo 400 to Amsoil 15W40 HD diesel/marine oil. This is per my mechanical oil pressure gauge, tapped into a downstream oil gallery well past the filter, which tells me the oil flows a little better.
Vaughn
"BLUE THUNDER"
'01 2500 QC Shortbed 2wd, Patriot Blue over Driftwood, HO 24v Cummins & 6-speed, 3. 54LSD, Cab & Fog lamps, Camper & Tow Pkg.
BOMBings: K&N RE0880 (NOT ANYMORE :(), straightpiped exh. , debadged body, AutoMeter Sport Comp gauges, Amber turn signals, 55w halogen rev. lights, braided stainless fuel lines
Performance: 245rwHP on BD Dyno, 0-60@ 11. 5 sec. , consistent 17-23 mpg
12,440 miles (7/27/00)
<font color=teal> My oil pressure is up using 15W-40 and the single bypass. If I had it to do over again I would have went with the 5W-30 AmsOil. Well I guess I can in 50K or so. </font>
Dee'sel
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, K&N Air filter RE0880 & Psychotty, TST #11 all the way forward, #12 for winter, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & TST 0-60 boost gauge in A Pillar, Hypo clutch ass. , Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, AmsOil ser 2000 75W-90 in Trans, Geno's trans filter kit, AmsOil ATF In Transfer case, AmsOil 15W-40 Oil W/ Bypass system, AmsOil Ser 2000 75W-90 in front & Rear ends, Lund Winter front, Leer Cab Level Shell Driftwood , 235/85R16 Goodyears, Dyno'd 342 HP *NRA/USPSA member and proud of it*
