I have a mechanical oil pressure gauge in my cab since I don't trust the factory oil pressure "gauge".
On a normal fall day when the engine is fully warm @ ~190* and an empty truck, it will read 60 psi at +2000 rpm.
On a 90* day when the engine is fully warm @ ~190* and an empty truck it will read 55 psi at +2000 rpm.
This weekend I was towing a friend's beater Chevy 4x4 with associated parts junk and was pulling this hill outside of town. I had the Smarty TNT Revo on #5 with a gross weight ~17,000 lbs. I was @ 2600 rpm, about 25 psi total boost (10 psi out of primary turbo), 900* EGT, and about 2/3 the way up this hill when I noticed my water temps hit ~225* or so on the stock gauge, but what really surprised me was that the oil pressure was down to ~45 psi. I then let off a bit because of the oil pressure. Soon after, I crested the hill and the water temps quickly dropped below the center mark and oil pressure increased to 55 psi.
I researched when I got home and found that sustained 225* water temps while working the engine is really nothing to be worried about. I also found that the Cummins service manual states a minimum oil pressure spec of 30 psi @ 2500 rpm. Regardless, it still surprised me how much the oil pressure dropped when the engine was working!
Is this normal? Does the engine oil soak up so much heat that the viscosity decreases to lower oil pressure that much?
I run Delo 15W40 and change at 7500-8000 mile intervals. Oil analyses always state I can go longer on intervals, but I just change at this interval due to my truck being modified just for peace of mind. I have never considered synthetic oil due to cost, but would synthetic oil cause the same oil pressure observations under similar conditions?
Before anyone scolds me, I know towing with 100 HP injectors + Smarty TNT #5 is a little "much" fuel and timing for really heavy towing :-laf, but I did take it relatively easy on the pedal.
