Engine/Transmission (1994 - 1998) oil pump
Engine/Transmission (1998.5 - 2002) Dead Pedal, Code P 0121 ?
Engine/Transmission (1998.5 - 2002) Cost of Diff. ratio change?
I am thinking of changing the oil pump on my 97. The engine was rebuilt 18k ago, but I reused the oil pump(160k). Now the trucks oil pressure is 10-15 at idle hot and 35-40 crusing at 1800rpm. The question I have, is there a high pressure high volume pump to use, or should I use a stock pump? Where is the best place & price to get one?
Thanks
Kevin
I'd bet your stock pump is fine. If you're using the factory gauge, try checking with a mechanical gauge. You may be suprised at the pressure readings.
Great place to check on top of the oil filter housing. Just remove the 1/4" plug and screw in a gauge.
Good luck,RJR
