How long does it take for a sealer to stop showing up on an oil analysis? I took a sample with 5918 miles on the oil and silicon came back as 24. On this oil I also fixed my KDP using high tack on the cover gasket, changed my valve cover gaskets, and installed a K&N 0880.
Oil was changed and sampled again with 4514 miles on it. Silicon came back at 20 this time.
Quote from blackstone:
"Silicon read at about the same level as last time, after a shorter run on the oil. You might want to consider another type of air filter to see if air filtration improves. Wear levels all ook fine and are well within the average range for this type of Cummins engine. No contamination of the oil was found, and we have no reason to suspect this engine had any problems as of the date the sample was taken. High silicon can also come from sealers and spray lubricants. "
Wear Metals were:
Aluminum 2
Chromium 2
Iron 9
Copper 1
Lead 1
Tin 0
I'm going out now to put factory air box back in and run this until next change, If silicon still is high, I guess it is safe to assume it is the high tack and new gaskets causing this.
Any suggestions?
Thanks
Chris
Wear Metals were:
Aluminum 2
Chromium 2
Iron 9
Copper 1
Lead 1
Tin 0
Any suggestions?
Thanks
Chris
