Oil Sample Test
Methanol over 5$ a gallon
Biodiesel sources in Austin, Texas
Hello to All
There has been a lot of talk of oil samples on TDR in the last few week's
and yes some of the issues are good some are opinions I think if you want to sample your oil and send it in and take advice from a lab that realy cares about oil then it money will spent.
It's no different then runing a race car and opening up the filter after each race to see if there are any bearing's in the filter. this has saved a few engines that I have seen from needing all new parts true the engine needed rebuilding but if ran it would have needed a new block crank rods pistions you name it it would have needed it. .
What I need is some one that has a 2004 dodge ctd with about 67,000 miles that is running Q State oil 15/40 to take samples of the oil and report the (Oil Condition Particle Count) it would be fine if this is old data from oil changes as long as the mileage is close and the oil used is the same. what its needed for is I just got my test back and some really strange things are going on with the oil . Nothing bad infact its great news but I need other tests to make sure its what I think it is.
Please contact me if you can help out
Thank you
Craig Hall
cj hall
-- email address removed --
