How frequently should oil be sampled for extended drain periods. I run Amsoil 15w40 HDD and dual by pass filter. I am coming up on my first drain ( 1000 miles to get all the gunk out that synthetics loosened up). When should I take my first sample after that and then how often after that? I realize that there is no hard and fast rule on this but respect the great minds of TDR.
ALso how often should I change my full flow filter? I use the Amsoil SDF 26, I'm thinking every 5k. How about my by pass filter, I use the Amsoil BE100? I'm thinking once a year (about 15K give or take, for me). Let me know if there is any other info that u need prior to answering.
Only other info I can think that would be of use is that most of my trips are fairly short, but usually always get to 190 on temp and let thermo open before shut down. I also let pyro go under 300 before shut down, 99% of the time.
Thanks in advancem
J-
Thanks in advancem
J-
